CV Shaft and Intermediate Shaft Question
RT4WD Q: I was wondering if you guys knew if the USDM intermediate shafts were all interchangeable (any models with d-series)? I have a lot of play where the Int. shaft and the axle connect and I'm unsure yet if one or both are the culprit, they will be disassembled soon here but currently I need to burn out a bushing first to remove the strut fork before I can get that far.
Also what would you guys look for with the axle or int. shaft that would cause "play" where the 2 connect?
http://www.bkhondaparts.com/billkay/jsp/catdisplay.jsp
