D16A6... am I holding on too tight?
The saga continues....my 88 RT4WD needs a motor, block is warped. I really want to keep it stock with another D16a6 motor. I bought an 88 RT parts car. Mechanic says, "just put a B series into it, I can get you one tomorrow." What is wrong with me? I don't want a B series motor, I want a stock motor and I want my baby to stay as mod free/stock as possible. The D16A6 is hard to find. I can get a salvage one for $500. Still seems steep to me but is the cheapest one I can find. No mileage given. 90 day warranty.
Am I holding on too tight to my D series? :roll:
All the parts can be had for $500, including a reman head.
As has been said the b-series swap into an RT4WD wagon would not be as easy as your mechanic seems to think. You would need to acquire a CRV RT4WD tansmission and customise the driveshaft. I doubt you will want to go to this expense and trouble.
Bam-bam is right on the money (as per), get your mechanic to check that the engine from the 'dud' RT4WD is suitable for a rebuild and go down the route. It will ensure many troublefree miles provided the work is done properly and the car is properly maintained.
Me, too. Somebody in Portland help the lady out!
I vote rebuild because the Japanese import motors are hit and miss.
So, I looked over angie's list/car talk site and I found a guy who seems like he knows whats up. He says he can't believe the cylinder hole in original car is warped. He laughed about it saying it was pretty much impossible. I took the car to him for a look over and he thinks my original engine is probably fine (WTF!) but that the valves have been poorly adjusted and the timing may be off. He votes to rebuild if necessary but doesn't think it will be. Then he won me over by saying, "This is the best car Honda ever made! You are lucky to have it! It's worth keeping it nice!" Which is better than what other mechs have said which is, "Why bother? the car is 20 years old." Or "It should get you around another 10,000 miles or so." This whole deal is wearing my patience. I want one guy who really knows his job and the car he's looking at. Meanwhile, the parts car I bought looks like something some of you mid-westerners would be stoked to have and I'm planning to part it. Seems like a shame. Maybe it can be saved whole after all.
Good luck with your A6! I gotta find out whats wrong with mine now.
if you need the specs for the adjustment here they are, straight out of my haynes manual
intake= 0.17-0.22 mm (.007-.009 inches)
exhaust= 0.22-0.27mm (.009-.011 inches)
thanks for those specs. I'm probably going to do this on my wagon. I've been having some ticking sounds from the top end!
Those numbers sound a little on the loose side. I'll check my Helms when I get home, but if memory serves me right, you should be shooting for .006" intake and .008" exhaust. I could be wrong though!
