Interior Trim Removal Pics? Help?
Hi All,
Just in the middle of removing my headliner to re-upholtster it and i'm running into an issue with removing the C-Pillars trim panels. Anyone have pictures and/or can help? Knowing pry points and or expected clips would be great. Snapping off all other trip has been quite simple but I have alot of resistance with the last area around the rear side windows.
Cheers for any help.
slide a butter knife down and pry with that....
Clear as mud, right?
Also bear in mind that the clips along the top edge of the window go straight UP, so you have to pull the trim down after freeing its lower edge (as opposed to out/ toward the center of the car)
Anyone have a diagram? Or the manual? Hrm, I think I downloaded an EF manual somewhere.. wonder if it has it....
much better answer than mine... do this...
