will this sway bar work
Will this work, and if so what more will I need to get it to work?
http://www.hondamarketplace.com/showthr ... ?t=2653512
My wagon is a Rt4WD with out rear drive train.
You might be better off with the Suspension Techniques sway bar kits that use the tow hook mounts to hold these same brackets. I'm pretty sure there are a few people here that have used that sway bar kit on their Wagon.
Thanks for chiming in to my answer guys!!
Please post a pic of your install!
can you take step by step install pics when you do this?
Don't know for sure, but I will sometime in the next while. I'll be doing it on my build. I think the ST bar stands the best chance of fitting, as it's most like the OEM setup as far as bar placement and attachment points.
im about to just weld a bar from side to side and win.
So all you would need for the above sway bar is the acura drop brackets ... the bushings should fit inside the normal round brackets and use the end links from the kit.
