10.5 afr at 2k cruising speed? Is my ecu shot?
I just got done installing my wideband and took the car around the block just to see what my afr's look like. The best afr I got was 14.12 pulling in my driveway when I just about stalled it. I don't have anything installed to datalog yet but i'll tell you what I did and what I saw.
I'll go rpm and afr under acceleration, Remember my clutch is still slipping so I wasn't hard on it maybe 30% load slowly stepping into it to max rpm.
2000-10.5
3000-9.7
4000-9.4
5000-9.2
6000-9.0
7000-9.0
and cruising 2000 10.5
I was reading the MPG thread and was wondering why i'm only getting 18mpg. Now I know why.
I do have an adjustable fuel pressure regulator set at 40psi, should I lower it?
I forgot to mention it's a dohc ZC and I have no idea what ecu is in there. They told me it's from an accord.
And I have code 6 bad temp sensor and code 9 bad cam angle sensor.
2000-10.5
3000-9.7
4000-9.4
5000-9.2
6000-9.0
7000-9.0
But for the time being I think my regulator problem will help with my fuel mileage problems. One way to work is 35 miles, there is no way it should cost me $5 one way in a honda civic. I was spending that in my chevy c1500 work truck with a 350.
Last, are you 100% sure your wideband is correctly calibrated? What brand is it?
The lean thing is just the first split second I apply throttle going into first gear. Driving it to work today showed me alot. cruising on the highway to work at 4000 rpm doing about 80 mph the gauge was showing 8.6afr. And again another half a tank round trip of 70 miles.
I'm using the oem naw from 14point7.com. I have been using his products for 4 years now and I have never had any problems.
But I will get a new temp sensor, if what you are saying about the limp mode is true that explanes alot.
By the way every crx over here had a DOHC ZC so if I can figure out what the part is in German I can probably get a cam sensor for you.
I tracked down my code 5, it was a broken vacuum T going to the map sensor. My AFR's are in check now. Thank you for the codes and what they really mean.
