*SOLVED* Hesitation at full throttle and cold idle.
So my last few tanks have had terrible mpg. during the time my car is running prior to reaching operating temp there is a fuely smell and if i tap the gas it hesitates, kinda takes a big gulp of air then rev's up. i've noticed A LOT of fuel coming out of the exhaust when i do this. i changed the cap & rotor, no luck. spark plugs look good. wires, good.
NO CEL.
NO CEL.
Is yours RT4wd or 2wd?
Fast Idle Valve or Electronic Idle Control Valve problem? Idle surge up and down too, or just runs/idles normal but rich?
O2 sensor might be bad, Check Engine light on or off?
plugs & wires are good, also just changed cap & rotor.
even if i am on the highway and i put the pedal to the floor, the car just bogs down then slowly sputters back to life.
When you pull the dipstick do you smell gas?
You could always stick a spark plug in the tail pipe and keep those tailgaters off your ass.
so ya, WOT causes hesitation. anyone had this before? did a search on honda-tech but no *SOLVED* ever came up. dead ends.
mine has done this before as well... MPFI'd 2WD
im looking for answers as well.. only thing i can think of is bad wiring somewhere.
does you wagon expel a lot of black carbon deposits?
let me know what happens when you re-do the wiring!!!
He speaks the truth. I need to do this on my car too.
They have a method in the car manual how to do it, but off hand you will need to back probe the TPS connector, and possibly adjust the TPS.
You can test the sensor off the car, get a old pot and boil some water, connect your meter on ohms across the sensor and put the sensor in the boiling water, watch the meter and the resistance should change as the sensor heats up, if htere is no resistance or it stays the same its time to replace your sensor
Also check the vacuum lines to the map "map makes me think of the bog issue, tps is more of a jerky feeling", test the coolant switch, test o2 sensor "one wire o2's are recommended to be replaced every 30k"
obd0 is hard to diagnose with no code, but save money and test the things you can.
There are good write-ups on here use the search feature and it should bring up test procedures - you are an elder you know.
If you did the conversion just double check the connections.
