Adjusting the clutch
So what's the best way to get to the adjusting nut on the clutch cable? Can you reach it by going down through the engine compartment or is it easier to get to from underneath the car? My clutch is getting really tight and I'm hoping I can fix that for the time being with a simple adjustment.
outcast
outcast
it can probably be done from the bottom too, i've never tried or needed to.
For some reason I thought the adjusting nut was on the firewall side of the transmission so since I couldn't see it over there when I was looking for it I figured I'd ask you smart people how to get to it. Once I actually pulled my finger out and followed the right line the location became pretty damned obvious!
I adjusted it a few turns and I got the clutch to engage/disengage about half way down the pedal throw (previously it was right up at the top), but the thing is still too tight and I feel like I have a racing clutch rather then a regular street version. I'm hoping to nurse this thing along for a few more weeks until I have access to a garage since Fall is in the air here and I don't want to work on this thing while laying in the mud.
Thanks again for the help.
the broken dutch pedal pivot pin...
the agony, the horror...
and whats that pin doing in...
!!!Yargghhh
