Ah, the dreaded "WOnt Start!" topic
Here it is,
My wagon has been acting up by not starting sometimes...Never the first start of the day, but usually a quick drive to the store for some beer and dinner or errands...come back to my new found little love, and...she says. "NO START, SUCKER!! Grab a book, relax..your not going back home right away..Lets just hang out here for a while and enjoy this parking lot, while we watch all the other cars come and go." While waiting, I hear a car next to me start right up and it makes me cringe :x I see my beers next to me... sweating in the sun...oh sooo tempting....
Then, after a few exciting pages of fishing regulations, she decides to fire up and take me home.
Until recently, although a bit frustrating, I thought this might be a good exercise of Zen-Like humility and patience. But...last straw for both of us... She never started :x And I had to walk home tonight without her.
TOmorrow morning, I'm going back with more tools and stuff to explore all of the usuals... spark, fuel...etc.. but I'm still new to fuel injection and don't know my new baby all that well..I did a quick search and found something about the main relay going bad..and how if a solder gets tired it will no longer send circut to the fuel pump...And then some stuff about checking the codes with the ignition,and looking at the little LED on the box on the passenger side beneath the carpet....... all new to me.. (I'm an old school carb guy...never had a fuel injected/computer before :?
Anyway, long story sort of short..so far, no go whatsoever with the cranking...just the starter rolling along with no "hello" from the motor...If I can't get her going tomorrow morning, the store wants me to get her out no matter what...That means the Tow Truck... So what could it be? And if it is the Main Relay could I just push start it to get the motor rotating in order to start it at least just to get it home?
Any, and I mean ANY experiences or suggestions would be welcome!
Thanks,WIl
So I need help fast!
Thanks,WIl
One day, I'm sitting at idle waiting for some buddies, she just dies on me. I checked relays, fuses, etc. I noticed that my dizzy cap was really hot, so I let it cool down. Took the cap off and turned out that my coil fried. Literally, it was crispy and falling apart. Replaced it, started right up and haven't had an issue since.
This fixed my problem, don't know if it's the same one your are having, but you could check out your coil.
Hope this helps a little bit.
viewtopic.php?f=16&t=739
What you described is what happen to me.Either it'll just cut out or becomes more frequent .I'm going to try adding a heat sink on the outside off the dizzy.
Now...here's the closer look. I pulled back the passenger carpet to reveal the Main Relay..yup..16 LED beeps..meaning from what I understand that the fuel injectors are not sending fuel. OK, BUT, when I get the light "beeps" at position #2, in other words when the main relay is talking, I DO hear the fuel pump priming, it WILL start when I go to position #3. I start it...turn it off..then put the ignition to position #2 again..this time no fuel pump priming, no LED lighting from the main relay. I try again to position #2--sometimes waiting as long as 2 seconds--I hear fuel pump priming (good feeling 8) ) and see the LED light blinking...Confidence builds....she starts
So...What gives? Is this normal? Is it the Main Relay that's being finicky or something else.. I never heard of a gasoline car that you had to turn the key part way, wait, then fire it up just like diesels. For the record..I'm old school and new to fuel injection
Thanks in advance.
Wil
I take it back..I can get a LED light sometimes without hearing the fuel pump priming..but sometimes there's neither LED light nor pump sound..but basically..car will not start without LED AND Pump sound. In fact, car will never start without pump priming sound. It seems I can usually achieve this by turning the starter switch key off and on until I hear it..then guaranteed start at position #3.
I'm trying so hard to be as descriptive as possible that I'm afraid I might be confusing the masses :oops:
I'm just excited that I know I'm getting closer to the solution
The main relay is a set of breaker points activated by a solenoid coil- the winding or contact points isn't usually the problem, rather the solder joints cracking. Classic symptom is starts when cold but not when warm.
http://fourthgenhatch.net/mainrelay.html
