OEM suspension parts compatibility
Hi guys,
Just wondered if you could clear some things up for me..
1) Wagon shocks are a bit longer than HB/Sedan/CRX shocks..?
2) Are the front forks the same as HB/Sedan/CRX forks..?
3) Are the rear LCA's the same as a HB/Sedan/CRX..?
4) Are the front brakes the same as the Si HB/CRX?
Thanks!
    Wagon shocks are same length as hatch shocks but the spring perch is lower down the shock body.
    Front forks are the same AFAIK.
    Rear LCAs are the same, year dependant.
    Front brakes are the same, year dependant. The RT4WD got the bigger pads from 88-91 whereas the Si only got the bigger pads from 90-91.
    yeh sorry thats what i meant with the shocks :lol:
    thanks for the help Haydz!!
    my wagon has some rusty bolts i want to replace, so may as well get some parts just incase
    i may try and upgrade the front calipers/discs to 262's too
    4WD Wgn also got larger frt.calipers(like CRX Si) than the the 2WD Wgn. :wink:
