Help dropping RT4WD oil pan
Has anyone dropped the oil pan on an RT4WD? The only manual I have is a Chilton's and it's somewhat vague on the steps. The first step is "Remove the driven gear from the transfer case". I'm assuming that is what the drive shaft is connected to at the tranny, correct? Do I have to drop the drive shaft first?
TIA!
TIA!
I think the cover that u want 2 remove is the 1 to the left(driver's side) of where the center drive shaft connects to the tranny.The cvr is about 5"(130mm) in dia. w/5 bolts in it.Once the cvr. is removed u should b able to see if the 2 bearing is bad.this should answer your other ???When I took mine apart.I found N
STUPID ME :!: :evil: I got the Wagon w/a bad tranny.R&R'd the tranny.When looking at the bad tranny on the floor.Saw a big HOLE in the cvr. described above.Had I had known this.I would've replaced the cvr.,2 brgs ,oil & probably b driving the wgn around 4months earlier.(& saved a lotta $$$) :oops: :oops: :oops: I was working in a friend's cold garage in 1 of the coldest winters in a while.
