4wd Suspenion... what's the deal?
it looks like whenever anyone is giving advice for the wagons here, it's always followed with "assuming you have a 2wd car"... why is there a difference? what is the difference? and what are the options for a nice ride for the 4wd waggon?
thanks
cody
thanks
cody
-cody
The only obvious difference is 4wd. I guess Honda felt there was some need for the higher spring rates or higher ride height for additonal articulation maybe, or to give it the look of a 4wd vehicle
Basically it comes down to this. The wagon's rear struts have a lower spring perch than standard 88-91 civics so if you use a civic rear strut use a civic rear spring. simple
Welcome to the board, where in Chicago are you?
the suspension is the only thing i had interest in changing, and this pretty much confirms i will be doing that, one way or the other. any suggestions for 4wd shocks/springs or coils?
-cody
The guy I bought my 2nd wagon from had a nice subie wrx, jus couldn't keep both cars so I understrand about you wantin to use the rt as a daily driver.
As fas as the suspension goes, there are a boat load of different opinions goin round. I am personally using some tokico blues in the front of the wagon from a crx, they're alright..like a step up from stock.
If you could I would suggest investing in some kybs or tokico adjustables. Also some K sports with the adjustable springs perches incorporated onto the strut body. I am in the process of approaching some vendors for suspension components to supply our board.
90-90 DA struts look like a good option too...
Give me your exact year make model and what you want exactly from the ride & we'll discuss.
thanks again
cody
Good point never thought of that.Maybe if you loosen the trailing arm bolts after the drop & retighten it.
