condenser fan fuse keeps blowing.help.
I was driving home from work the a/c was perfect then it just started to blow hot air. I saw that the condenser fan wasnt turning on so i checked the fuse and it was blown so i thought i found my promblem. I put another one in with the same amperage and it blew as soon as i turned my a/c on. I tried it like 6 times using the same amps still nothing. It worked for a while when i put a 20 amp fuse but still blew after 10 min. But when i unplug the compressor power it dosent blow at all. Seems like it only when the a/c is functioning. Could it be my compressor? Please help.
  • JakerJaker familEE
    I'd guess it's the condensor fan that's overloading the circuit. Check you fans to see how stiff they spin. There should be little or no resistance.
    I'm trying to remember- are the compressor and the fan on the same fuse?
