6 speed?
What's the deal with these cars and six speeds? I've seen a couple on the board here... is this a factory option? or is it something that is swapped in? I can't seem to find a definite answer to this question...
thanks
cody
thanks
cody
We have a super low, pre 1st gear for off road creeping, towing loads etc
cody
All of the 4th gen RT4WDs have this gear, it locks the centre coupler and as sic944t says, can climb hills better than most trucks or other 4WDs.
i pick my red '90 RT wagon up on Sat. should be a fun drive home...
Cody
The viscious centre coupler? How does it do that?
Where did you get the info from that it was doing that ? Honda?
See, if it's designed to lock it up then being the way Honda are it'd make me think that the system might be able to cope happily with a locked centre diff all the time.
I know people here have done it but it's still a reasonably scary thought
It's just something I want to get to the bottom of for the why and hows. If it's doing this then it makes SL the choice of launch gear really.
:? 1/2 wrong.1/2 right .The Viscous Coupling(VC) and the SL are separate issues.The SL gear is the best launching gear,but it'll take a BIT of practice to shift from SL to 1st.
If the centre coupler & the Viscous Coupling(VC) are the same.SL does NOT lock the VC.The VC is purely mechanical .When the VC senses more than a 10% slippage it engages.The VC is oil & clutchplates hence the term "Viscous".I believe later year Shuttles may have used a electronic engagement when Honda merged the VC with the rear diff.Look under "LSD" in this link:
http://www.hondacivicwagon.com/board/vi ... .php?t=595
They never merged the centre coupler and rear diff on the Shuttles that i know of - i never used to be able to see the VC on my car until i had a really good look but it was definately there - just smaller that the USDM ones i had seen and slightly further to the front.
On an added note, when i shorted out the ALB system the system would also lock... indicating some form of electronic control. :?
Nominous, we tested and tested with the Shuttle up on jacks and also running her on grass and found that the SL was locked centre.
thank to you i finally found the sl gear
same here. when i baught the car it came with a 98 integra gsr shift knob. i knew it had an sl but couldn't figure out where it was. even after you description it was still hard as hell to get it all the way left.
wasnt there a funny story as to how you discovered SL? eh eh?
It involves a monkey, a piece of string, a gearknob and two fish hooks.
Good, because I recall reading about your shuttle and being from the land of JDM it was decidedly different with the rear LSD and at the time you said it had no VC joint.
Yes. I'll go with that. I'd guess that it played with the diff in some manner now, however previously what with your car having no VC that you could see it actually made more sense having an electronic rear diff control.
I honestly don't see how that can be conclusive compared to the same test done whilst in 1st. :?
Perhaps the gearing would allow things to move more freely, but if the VC was locked and all four corners on stands, if you tied the rear wheels to the ground it would stall.
Also when tied down (see kiwi backyard burnout pad) in 1st the fronts would move first and then the rears, but in SL the car would start spinning all fours right away.
That's how u test the VC except you'd apply the hand brake.Wgn stalls...VC works.Wgn doesn't stall ....VC bad.
Anyone ever ripped a VC apart ?
It was merged see link:
http://www.hondacivicwagon.com/board/vi ... php?t=2766
