  • DarrenDarren Wagonist
    You can figure this out by hooking up a source deck and just locating the wires, then once you've got them all located and labeled, wire & solder the connector in.
  • Thanks darren, Where could I get a source deck? And what exactly is that? I have the soldering gun and heat shrink tubing for when I get it right but still have no idea whats what.
    Main color-Line color-
    Brown- Black + Right front -
    Black - None = 12v ground
    Brown- White = Right rear -
    Blue - Green + left front positive.
    White - Green
    White - Blue
    Gray - White = Left rear -
    Blue - Yellow = Left rear +
    Red - Green = right front +
    Gray - Black = left front -
    Red - Yellow = Right rear +
    Red - Black =
    Okay here's what I got left.
    I need a 12 Volt battery constant.
    An illumination or dash light.
    And a 12 Volt ignition/ switched.
    If anyone can help it will be greatly appreciated
  • okay so while I'm waiting I wired up the connector to the alpine sterio.
    1.jpg?t=1248408831
    Its all soldered together Then heat shrink tubed then a layer of electrical tape.
    1.jpg?t=1248408913
    Hopefully tomarrow if the weather is good I'll get in these bad boys with an amp.
    1.jpg?t=1248408961
    i got a stereo wire harness clip thing from a 91 sedan for my wagon (because mine was also cut) and it had the exact same colors as my cut wagon one :? it should match up..
  • Okay thanks Wago. So here's what's going on. The red with a black strip is the 12 volt battery constant. Now for the alpine radio I still need a ignition switched lead. And I have 2 wires left. the same color with a different strip. so I'm going to just try both wires because one is the illumination wire. (that I don't need for the radio) and the other is the ignition. sorry but I'm just tired of failing at hooking up a stereo.
    Nice over kill on the electrical tape :lol:
    I would recommend getting the right radio clip, like wago said it'll just be matching colors (easy as hell).
    If you choose to figure it out how you have it then on the top of the Del Sol radio it SHOULD have a chart that shows where the plug wires go (meaning the one you have with the wrong colors should plug in there and then you shoudl be able to tell which one does which)
    White/blue = constant (I believe)
    White/Green = switch (I believe)
    Red/Black = lighting (dimming I bleieve)
    Black = Ground
    Blu/yel=+ Left rear
    gry/wht=- left rear
    red/yel=+ right rear
    brn/wht=- right rear
    blu/grn=+ left front
    gry/blk=+ left front
    red/grn=+ right front
    brn/blk=- right front
    Hope that helps.
