Clunking in the rear end on the RT4WD
Well , inoticed the rear end clunkcs when i drive...
ive never owned a rwd/awd car b4..
what could be the problem?
U-Joints maybe? the rear diff doesnt leak i dont hink, but i should prolly change the fluid
Worn out suspension bushings are a common culprit.
The RT4WD dont use u-joints, they have CV's like the front - IRS!
i guess ill just ignore it, and turn off 4WD
Of course when my tranny blew 200 miles from home the clunking noise became irrelevant. I think maybe its just the rear end trying to engage for some reason since it usually happened when I was shifting hard into second. I don't really know what factors cause it to engage.
Does anyone know if clutch or tranny problems are interpreted by the 4WDs as a loss of front end traction?
Vince
http://www.hondacivicwagon.com/board/viewtopic.php?t=87
