4WD transmission ratios (84-87 vs 89+)
In the midst of a rebuild of a '89 RTawd trans.... happened to have both a '87 and a '89 on a table at the same time. Exterior wise, the cases are similar, but different and not interchangeable (different rear trans mount bolt pattern, different but similar gear change assembly, etc).
Anyway, here's the gear ratios and teeth count for both gearsets. If anyone can confirm or dispute any of this info, please post up.
I will more than likely end up using the '87 3/4/5 in the '89 trans, since they're only a little longer, and the engagement dogs are in 50x better shape.
D
D
The only size difference i was aware of is the mainshaft (87 and earlier being smaller input spline). gear diameters and surface area are very close if not the same (depending on gear ratio). Only other strength difference could possibly be due to the case design itself, which the differences are pretty minimal. I can't see how the later trans could have a higher torque/load holding capacity.
actually my output shaft broke on my 89 and the splines on my 88 were striped to hell I had a week clutch on my 88 but there is a major diffrance(I think) in they way they shifted my 88 was pretty rough
Just to re-iterate. Transfer bevel gears of the early style case (84-87 4x4 and RT) are interchangeable with the later style case (89+). They are not weaker, they are the same. Period.
clearly not true... if the gears were the same the ratios would be the same ... which there not... according to the HONDA manuals that i have
so i really dont know what your talking about... they might be interchangable but they are not the same.. period
Edit:
Info provided from jaker: "In the 1988-91 transmission, they are most definitely not 1:1. The drive gear is 21 teeth, and the driven gear is 19 teeth. Here's a couple of pictures showing that."
So, thanks to jaker for the correction.
And i pulled part #'s from the honda/acura EPC...
Transfer section bevel gears:
86 4x4 29210-PH8-010
87 RT 29210-PH8-961
88 RT 29210-PH8-900
89 RT 29210-PH8-900 and 29210-PH8-910
Transfer bevel gear bearings
86 9122-PH8-008
87 9122-PH8-008
88 9122-PH8-008
89 9122-PH8-008 AND 91122-PS5-003
Transfer Shaft
86 29201-PH8-000
87 29201-PH8-010
88 29201-PH8-900
89 29201-PH8-900
Transfer shaft collar
86 29311-PH8-000
87 29311-PH8-000
88 29311-PH8-000
89 29311-PH8-000
All i have access to currently are 2 early style 84-86 4x4 box's.... i'll pull the transfer section out of them both and confirm. I am curious why the suffix code on the 87RT bevel gears is different from the 86 4x4. Apologies for any misinformation.
understood and agreed
