Are my compression numbers good or bad?
I prefer to be optimistic but damn this wagon is turning into a headache.
170-15-150-170
Notice the 15?
I'm really debating whether or not to keep this car right now.
I suppose I should keep this tech related.
Will a rt4wd oil pan fit on a d16z6 longblock fine?
-Shane
170-15-150-170
Notice the 15?
-Shane
I believe that the RT4WD oil pan will fit a Z6 long block, since it's all the same block anyway. Though a decent used D16A6 would be easy and cheap to find. The one in my gf's CRX cost her $50.
When I drove it I was thinking "it really feels like 15 psi on 1 cylinder"
j/k I just thought it felt like it was running off of 3 cylinders. I hoped it was a fouled spark plug or a bad dizzy.
Tomorrow looking at a d15z1 motor. If it looks good I'm getting it and the rt4wd will be a nice gas saver.
I'm well aware of the wiring and other things needed to have this run properly in a car. after all I put one in a crx about 4 years ago, did all the wiring myself too!
Could just be a blown head gasket, or a single valve... If you have the abililty to swap an engine, you'd have the ability to fix a head gasket (deductive reasoning) and it'd be cheaper
IMHO
x2
Everybody always resorts to swapping. Get some air in there and figure out where its leaking; fix it (head gasket? might as well clean up the head with some new cuts and valve seals) on the cheap.
I've done a B17A1 (GSR) swap, and i'm just completing my 2nd B18C (JDM ITR) swap in Crxes and it's a pain in the butt... never goes very smoothly, especially with the wiring, and the cars inevitably down longer than you wanted it to be.
I've also done 3 or for motor changes on my 88 Accord Coupe and it's much easier, i can have a motor "swapped" out in a day in that thing, just simply because it's plug and play.
Not trying to convince you NOT to do a swap, just saying you should go through the troubleshooting, and research to determine what direction you really want to go.
There's good and bad points to swapping motors, you have to look at what you want the outcome to be.
I've got a complete d15z1 swap :twisted: the only thing I am lacking is the egr box (which it sounds like I have a couple I could get)
I have everything else. I will begin the process this weekend. I have access to a welder, so I'll prep the vx manifold/cat to fit the rt4wd oilpan/drive train.
This time next week it could POSSIBLY be driven.
I guess I'm using the low compression as a reason to do this swap
I'm debating open up another thread of my mpg build!
So you may need to rebuild the bottom end of that motor anyway, then add the D15 head onto it.
hmph, thanks for pointing that out. I"ll get it to work.
You'll also be able to play around a little bit with what pistons you want as well.
Any tips on how to remove the tranny? I have never dealt with cable shifted trannies before. It is manual.
Thanks,
Shane
Made up a custom bracket for one of the intermediate shaft holes, left one open, and the other one bolted to the block.
I am going to run the light weight d15z1 OEM flywheel. Any issues you are aware that could happen because of it?
I was taking it around a on ramp (little excessive in speed) and CEL 22 came on!! Otherwise I had code 48, got a good sensor and that went away!
I have more tweaking to do. I'm still being optimistic of hitting 40mpg. I really want to take off the intake manifold and clean the egr ports and have the fuel injectors cleaned.
And I MAY do a headgasket but my compression numbers were decent (170-180) so I"m a little hesitant. If I did headgasket then I would do a clean up of the head which would net a some better MPG.
I have a vacuum gauge I plan to hook up to help monitor my foot
I'll try to get pics up sometime soon.
