Source for replacement lca bolts
So, in our attempt to remove the broken driver's side rear cv axleshaft, we managed to snap one bolt and had to grind another one off. Is the Honda stealership the only source for these bolts? I know I can get the bushings I need from Napa or other parts stores but I didn't see any bolts. Thanks!
i eventually replaced it with an OEM bolt i pulled from a junkyard car.
they are pretty cheap at the stealership though, i think less then $3 for one. its been a while since i looked it up though.
i'm thinking now of just upgrading my LCAs. any suggestions? blox etc? nothing too expensive though.
James
