What's the secret to removing hub nuts at the yard???????
I found a 90 Ex and was trying to get the brakes, but one I couldn't get the bent tab on the hub nut out of the little gap, and two I couldn't figure out a way to lock the axle so I could loosen the dam thing. I've seen Bam-Bam's wonderful tool he made, but I have no metal working skills.
Any help would be great, I don't want to pass these up. The car is close to the point of being scrapped.
If that doesn't work, bring a GUN, I recommend a 12 guage.. Won't get it off, But at least you'll feel better....
If all else fails, just pull the axle from the tranny end and take it with you! Or...if you don't want to pay for an axle pull the CV apart.
It's not necessary in my experience to bend the lock flange of the axle nut back up out of that groove. The nut will come off fine once you break it loose.
