are there any upgrades for a crv's rear end and axles im trying to make 375 hp to the wheels. i dont think the rear will handle it at all. does anyone know of LSD;s for the crvs too?
I put 94 Integra front hubs into the CRV rear bearings on my Wagon RT4WD rear trailing arms. It took some messing about to get it to all fit, but it's in there. Then I had Drive Shaft Shop make me some custom length stage 2.9 rear axles with Civic inner joints and the Teg outer joints they use for this stage of axle. I am using the RT4WD Wagon rear diff with a modified OBX LSD for the trial. If everything works, I will be upgrading the rear diff to either a modified Quaife or KAAZ LSD. Do not know for sure which one I will be going with.
think this should work on a crv and use a wagon rear with LSD? here is another question are auto and stick rear ends the same as far as gears and stuff?
If you're talking about crv rear ends, I believe the rear diff and gear ratios are the same...
2001 KA 4AT carrier sub-assembly RR differential 41010-P6R-315
2001 KA 5MT carrier sub-assembly RR differential 41010-P6R-315
interchange info:
