I just noticed my driver side front axle (outer boot) is ripped and just started clicking when i turn, would it be okay to replace the boot or should i just replace the whole thing?
Agreed, an axle swap is as easy as 3.141592654. (Pi ) I let mine go for a while after I got it, and it was clicking then. When I finally got around to replacing it, the inner CV joint FELL APART as I removed it. :shock: Clearly I let it go too long. I was lucky it didn't fall apart while driving.
Is your wagon FWD or RT4WD? If FWD, getting the right part will be no problem at all - your drivetrain is the same as a Civic/CRX DX which is as common as dirt. If RT4WD, be careful. The number of splines is different, and the driver's side is A LOT shorter than FWD models due to the intermediate shaft that only RT4WD models have. The local Advance Auto Parts got me the wrong axle. Twice. And couldn't get the correct one, it seems. Their computer is wrong and that's all they can go by. Fortunately I only really needed the passenger side, which they got right on the first try.
~kevin
