Lancer Evolution Recaro Install Using Wagon Rails!
I did it, and I'll show you how!
I originally had planned on using the Evolution's factory seat rails, and just bending the tabs into the appropriate position. It seemed like it would work, at least it had on both my '94 Integra and a friend's '94 Civic. That didn't work. :lol:
So while I was tossing things back together, I had laid the Recaro next to the stocker on the floor, and immediately noticed something: the bracket bolt holes were oddly similar between the Recaro seat bottom, and the tops of the wagon rails. If I had to guess, the holes were less than 1/8" further apart, front to rear. I didn't actually measure anything, but I'll wager to say the Recaro is about 1/8" wider as well.
Pictures are with my phone [Samsung Blackjack 1], apologies for the poor quality/blurriness. :mrgreen:
So I started tearing things apart, and quickly found out why my car smelled so peachy ...
Looking at the bottom of the wagon seat/bracket combo, you'll notice three large gold bolts [fouth one is hidden in the top-right under the seat rail] holding the rails to the seat bottom:
It's difficult to tell in this picture, but there are two bolt holes directly to the left/right of the springs on the bottom, and two more just to the left/right of the yellow line on the top:
Here is one of the wagon rails mated to the Recaro seat bottom [seat back was removed for ease of fabrication]:
A close-up of the hole ... not very far off at all!
I had to grind one side flat on the bolts I bought in order to get them to fit inside the structure of the Recaro without turning as I torqued them down:
And the driver's side seat rail bolted onto the seat:
One particular bolt had to be ground down on two sides to fit a rather narrow section of the Recaro's structure:
And the passenger side bolted in!
Here's the seat bottom, bolted into the car:
* Yes, I left the Peachy-Peach scented tree on my floor. :lol: *
And the finished product:
* A side note: due to the location and thickness of the bolt-heads which I used to fasten the Recaro's seat structure to the wagon seat rails, I had to grind down a portion of the seat-back bracket to clear them. If you use allen-head screws, or thinner bolts, you will not encounter this problem. Also, I had to install the seat bottom before the seat back, otherwise I am unable to reach the rear seat bracket to floor bolts with a ratchet. I also left the plastic trim pieces off the sides of the Recaro, as I would be unable to get a phillips' head screwdriver in such a tight space to secure them - it looks fine without.
Total investment:
$2.09 for bolt/nut hardware
$150 for the Evolution Recaro from a 2005 LanEvo GSR
1 hour of my time
The bolsters are a night-and-day difference between stock and Recaro, and having harness holes is a definite plus, as I plan on a harness and harness bar in the near future for track events. The seat sits about two inches lower [complete guess], but is about the same distance from the wheel as the stock seat would be [still has the same fore/aft adjustment as stock].
I recommend this to anyone looking for a cost-effective upgrade that will hold you in on those rally/canyon-carving/trackday/autocross excursions.
  • 5th element5th element Band Wagon
    they look really nice bro, wish i can get some seats like that
  • jpciiijpciii familEE
    OMG, awesome thread!
    I wonder if regular Lancer seats fit as easily...
    Good stuff, Dave! We always see the Honda/Honda seat swaps, way to think!
  • Has anyone done any research on if all Lancer seats use that bolt pattern? This could be a major step towards a massive amount of available seats for our wagons.
    Exactly. I don't need the Recaro, I just want something that isn't ripped... preferably in brown.
  • JayPee_incJayPee_inc Band Wagon
    NICE!!!!! do you sit any lower? or is it the same because u used wagon rails. i would guess the same.
    those seats are tits. i would totally get a set......
  • JakerJaker familEE
  • SICKKKKKKKKKKKKKKKKKKKKKKKKKKKKK can you post a pixxx of the front view....
  • another question to ask would be, is your wagon with or without autobelts. if your wagon is manual belts do you think this would work for the autobelt systems in the 90-91 wagon?
    good job! i love ppl like you...
  • Dave-ODave-O Wagonist
    I'll try and post up a pic tomorrow - by the time I get out of work it'll be dark outside.
    My wagon is an '88 with manual belts. I'll hopefully have my hands on a '91 seat/retractor assembly soon, so I can definitely check it out. If it's how I think it is, the retractor box is a part of the seat slider and bracket, and not the actual seat, and if that's the case you'll be able to remove the OEM seat and bolt the Evolution seat to the Civic slider like I did with my manual belts.
    Blame my ADD and OCD, and lots of Mountain Dew.
  • Mountain Dew ftmfw!!!
  • debrisdebris Wagonist
    What was the weight difference?
    I haven't weighed either seat, but I'd estimate the Evolution Recaro to be 2-3lbs lighter.
    And yes, Mountain Dew FTMFW. :mrgreen:
  • dirtbagdirtbag Band Wagon
    hell yes! dave is the man! i am the current owner of this wagon!
    looks good man.
  • JesseCRXJesseCRX Council Member
    Nice discovery!
    How low do the seats ride?? Or are they more or less the same as the OEM seats in ride height?
    so doing this
    want to get rid of the nasty burning platiky seats
    for these nice smoot ones :mrgreen:
  • sometimesidosometimesido New Wagonist
    very nice!
    I wonder other recaro seats would fit this way.
    This thread made my day!
  • Thanks for the tips. I need to mount my new seats.
  • FernpatchFernpatch Band Wagon
    My wagon is an '88 with manual belts. I'll hopefully have my hands on a '91 seat/retractor assembly soon, so I can definitely check it out. If it's how I think it is, the retractor box is a part of the seat slider and bracket, and not the actual seat, and if that's the case you'll be able to remove the OEM seat and bolt the Evolution seat to the Civic slider like I did with my manual belts.[/quote]
    Did you ever have the chance to check the 90-91 seat rails to see if they would fit as well?
  • Mister DA9Mister DA9 Band Wagon
    Hella sick! Nice find!
    Picked up a set of 8's last night. I'll post pics on Saturday after they are both in. This will be with auto belts, so I'll post up pics of the process if I need to do anything differently.
    So, all of my allen head bolts on the EVO seats will not budge...none. That being the case I really need a high speed air cutter and compressor (or a good plug in version). I can assure you that a dremmel and hacksaw kinda suck. My compressor was stolen a couple months ago and I really should have bought another for this project. That said, I'll post up hardware dimensions as well when it's all said and done.
    The RT4wd seat brackets seem to be vastly different then the FWD brackets, or the 88-89 might be different than the 90-91. Not sure which is true (Im assuming it's the RT4WD that makes it different), but regardless this has become a full fledged project, and I envision having to fab some brackets.
    F.
    45m later: Yup...gonna need to take brackets into machine shop at work to get everything to fit. Need to cut off and grind smooth a couple of large brackets on the outside rail of the wagon to get them to mate flatly to the EVO seat frame. The auto belt side should be fine I think but the outside wagon rails mount to the side of the wagon seat not to the bottom, and there in lies the issue. Im going to have to cut off those flanges, drill some holes in the wagon rail and then I should be able to mount them. Also, the hex bolts on the EVO seat have some serious loctite on them.
  • i found a set of 02 lancer seats for 100 bucks locally...thinking about picking em up, but we'll see how they look.
    Well, I think I have a solution.
    My initial problem was that I wanted to incorporate the OEM rails because I needed to keep the auto belts. But after thinking about it last night I realized that I can use the EVO adjustable rails (the mounting points for the EVO just come off of each corner with a bolt) and make my own mounting points. This would be the ideal way to go for someone w/o auto belts, but I assumed that w/ auto belts you couldn't do it. Then it dawned on me that the auto belt mechanism is held on to the OEM rails with two nuts. So when I make the new mounting brackets to line up with the OEM wagon floor holes, I can just make an attachment to attach the auto belt mechanism to!
    I'm not yet 100% sure this is going to work, but I'm pretty confident that it will.
  • im goin to pullapart tom!! and possibly look for some lancer seats. i wonder if a Pulsar seats woulds fit. yummy.
  • i found some of the mirage 2doors seats. i found them pretty interesting and cool.
