Broke 2nd pedal box!
So today i was driving home from the lake and was unable to shift into any gears suddenly. i pull over, tighten the clutch cable which seemed loose. yay, on my way again, smooth like butter. make it another 50km... toasted clutch pedal pivot rod snapped and the clutch pedal just lay against the floor.
was able to nurse the car in 1st gear to a shop. i pulled the pedal box in the parking lot and he welded it up for me. this is my second pedal box replacement/repair! So if you suddenly think your clutch is toasted, get under the dash and inspect your pedal box first. the first time it was a hairline crack that was causing problems.
PS. THIS IS NOT A FUN REPAIR!!!!!!! my hands are cut to shit from trying to squeeze them under the pedal assembly. i cursed god and all of his followers for about 10 minutes. you need little rubber arms and hands to do it. now my clutch pedal is stiff right at the top, so i need to go adjust it. booo.
I would suggest rather than just weld/repair your current pedalbox, purchase a known good unit and reinforce the area where the old one started to crack.
Obviously you were in a situation where you needed it going there and then, but maybe food for thought in the future.
5 years ago when i replaced it the first time it was from a good donor car. I was having the same problem you mentioned above. We replaced the clutch before finding the pedal box to be at fault... that was the worst part.
This time it was the pivot rod that broke, it looks way stronger now than it did OEM. very happy with the repair. my hand looks like i was punching a bag of nails though, from all the cuts and gouges under the dash.
Get some light under the dash, get your head under there and press on the pedals, it should be fairly obvious if you've got some excess movement going on. if it's not obvious, it's probably not the problem.
I dread getting back under there but I'm having some trouble with the throttle cable sticking at the moment.
house-sitting someone's cabin/cats at the lake for the weekend. nice.
