rear axle seize?
So I am removing the 4wd system on my wagon, I have removed the rear diff, driveshaft etc. My axles are hanging down in the rear not attatched to anything... I have taken the 32mm nut off the outer end of the axle. I CANT GET THE AXLE OUT!! I know I have to leave the outer chunk of the axle in to hold the wheel bearing together, but I can't get the axle out of the trailing arm... Is there anything else that needs to be removed to get the rear axle to slide out of its home? I even took wd-40 and an air hammer to it with no luck... Any suggestions?
You can take the hole trailing arm to a workshop with a hydraulic press, and press the axle out.
or do what i did.
i took a spare axle nut, ground the piece with the tab off, and welded it to a large bolt, could weld to any number of things.
then i screwed the nut back on the shaft and smashed the end of the bolt with a sledge hammer
Sounds crude, but it works really well. just make sure #1 that the end of the bolt makes positive contact with the axle shaft, once the nut is done up tight.
#2, you can only move the axles about 10mm like this before the nut hits the spline, but that should be enough anyway.
Just screw it on and smash it with the biggest hammer you got.
