not sure what you are asking in the lastpart of that sentence, but 'JDM' moldings are the same as USDM )only difference can be the decal along the back door noting different models) the red stripe is just a few peoples' own creation using a pinstripe.
ive seen other moldings on the car, i was hoping someone on this forum was up to date on possiblities of the wagons ive seen with my own eyes moldings from efs but i didnt ask that particualar person about them
The wagon has the same door skins as the sedan, so there is no logical reason why the door mouldings from a sedan will not fit the wagon. They are narrower however. I can't say for sure if the fender moulding and 'dog-leg' moulding (behind rr door) will work or not. Also, the 88-89 hatchbacks and sedans had the mouldings with the spot to put the stripe (and some JDM upper models had an OEM stripe in them), while the 90-91 hatch and sedan had different mouldings that had no spot for the stripe. The wagons had the same mouldings all four years in the US. The 4WD just has the sticker.
If you've seen other mouldings on the car you might be thinking of a very old pic of my first Wagon, the Civic Pro. It had different mouldings because the Civic Pro model never actually came with side mouldings. The mouldings were aftermarket from Japan and i have no idea what they are called. Here is both of my Wagons from a similar angle to compare;
wagon moldings are wagon specific.
The mouldings are Wagon specific and people just get the pinstripe from paint supplies places.
The Hatch/Sedan/CRX mouldings don't fit.
The Civic Pro
The Shuttle RTi
