4-2-1 header in a rt4wd
close to getting my wagon back on the road. found a big crack on the back of the exhaust manifold so I figured I'd order a ebay 4-2-1 header. Now i just caught wind that there is a clearance issue with the transfer case and these headers.
I'm holding off on ordering the header untill i find out about this. But at the same time I'm starting to get in a time crunch with this.
So what are the mods to make it fit? I'm not set up to weld SS so that's out of the question. Any "shop" welding around here is usually roughly a $50 minimum. And you never get charged the minimum.
If anybody has pics of the mod that would be helpful too!
wagon.........................4ever...............
I got some feedback from jackmarkgraf that the 4-1 will not clear either.
Read some reviews on the 4-1's that would fit. Problem with those is the the initial tubing length before they merge isn't long enough. I don't understand header dynamics... but the general jist I got was that if it fits, it's probably not worth buying.
Yes but you can hammer/bend/fabricate a header to work. slammedtallboy was running a header on his rt4wd, just had to do some hammering to get it to fit.
x2
Ive had my header reconfigured twice. If you have a exhaust guy you trust, they can pretty much do anything.
wagon................4ever................
I am doing exactly that on my RWD conversion, and I need to make sure I can fit the 3" pipe I'm going to use on my collector. I have a Kamikaze 4-1, and all I need is to run the 3" pipe from the collector which is in the same place as yours to the flange near the steering rack.
That came out pretty slick!
So..... when you go turbo, what are you gonna do with that setup
keep me informed!
The 'bottom tube' from a SOHC ZC that came out of a JDM RT4WD vehicle should work fine - it did for me on my RTi. I used the top half of the manifold from the DOHC ZC and the bottom half of the manifold from the SOHC ZC, this gave me 4-2-1 but still cleared the transfer case and sump.
shit! :?
