Best Year?
Hi all, just joined as I have recently discovered the Civic Wagon, and am seriously in the market for one. I browsed and searched through the forums for the last couple of days, picking up a lot of info here and there (still have more questions though)
I looked at an '85 today but I think it had the carbed EW1 engine, so I am not considering it, even for the $600 the guy was asking (body in very good shape for the year, but I've seen better interiors at the junkyard)
I found 5 others listed locally, one for each year from 1988 to 1991. I am really only looking for 5 speed (and the best mpg) any suggestions on the best year? I have heard that some are reporing hwy mpg in the 40's .. second queston... is that mpg accurate and realistic or just an empty boast
I am seeing prices for running wagons from $900 to $2700... and the middle of that range seems reasonable. ANything specific I should look out for? The only thing I know is to watch for rust inside the wheelwell, and I think the hatch hinges.
Thanks - I look forward to going from a wannabe to a legit owner by this weekend.
CHeers, :?:
Jacktar
CHeers, :?:
Jacktar
main difference that people seem to gripe about are that the 90-91 had auto-belts. personally i dont mind them at all.
the 90-91 had a mild freshening when it came to some interior parts (smoother gauge cluster for example), the front corner lights didnt have screw holes anymore and the bumper lenses were clear.
gas mileage: it all depends on how YOU drive and how you maintain your vehicle. the absolute best mileage i ever got was 46 MPG when i was touring across the flat lands of Indiana taking it easy doing about 65 mph. my average ranges from 34-36, and that includes highway and city driving split about 50/50. worst mileage i ever got was 29 MPG.
i may point out i have a 2WD model (with MPFI conversion, 2.25 in catback exhaust, performance header, 8 inch wide tires, lowered about 4 inches and front lip), also i am a pretty relaxed 20 year old guy with the occasional high revving spirit.
the 4WD model will get your average mileage in the 20's to low 30's. i usually read people talking about getting 26 average with 32 on the highway.
so it all depends!
The USDM '88 RT4WD had a slightly less powerful D16A6 with 78.3Kw vs. the 80.5Kw of the 89-91 models
RT4WD is obviously heavier...
Other than what Martin said that pretty much sums it up as far as i can think.
:?: what about the 89's? 2wd and the rt4wd.
To me, the ultimate wagon is an 89 manual RT4WD with no rust.
If it weren't for the one awesome - only available in 88' - one off silvery blue metallic color of 88's then I would agree with nerdy that 89's trump all. Although if any modding is in the future then things like clutch, RLCA's and corner lenses can all be swapped over for new(er) parts just like the other models.
I've got a silvery blue 89:
Speaking Civics, not wagon specific:
88-89 is the same, minus the transmission and rear LCAs. The seat bolt patterns in my hatch (89) is narrower than 90+. Making it hard to find seats, due to seat belts being on the floor, rather than in the door. With the seat belts being in the door, there was more support causing more weight in the 90-91.
The 88 had funny eyelet lower strut mounts, for the LCAs, where as 89-95 share the same rear LCA and lower strut mount.
The 88 had a 21 spline transmission, and 200 mm flywheel.
The 89 had a 20 spline transmission, and 200 mm flywheel.
the 90-91 had a 20 spline transmission, and 212 mm flywheel.
So to sum that up, the 88 is an oddball transmission. The 89-91 share the same transmission, but the 89 has the oddball 88 flywheel. SO, you can only use an 89 clutch with an 89, unless you swap to a 90-91 212 mm flywheel (which is what I have done with my 89 SI).
Other than that, it was all aesthetic. Seat patterns, color options, side moldings, corners, bumpers, tail lights (I forget that 88-89 had 4 bulbs, 90-91 had 5), etc.
Good luck in your search. Im hunting for one myself. Im leaning towards ANY 88-91 RT4WD. I have learned with my ED, that it is a much smarter decision to look for the model/body style you desire, in clean and rustless condition, rather than year specific. You can change a lot between years. Such as my 89 ED rocks 90-91 sidemoldings and bumpers.
but...I have seen 3 different clutch disc diameters. I have one out here somewhere with the 90-91 spline hub, but between the diameters of an '88 and a '90-91.
