wago turnt on but turns right off
i will turn it on but it turns right off. if i do it 2 or 3 times it starts. what is it?
starter?
if so is the starter from the dx the same? (i have an extra one from the d15 in my garage)
starter?
starting but stopping immediately could be the following:
-loose or faulty connections at the distiubtor, coil or alternator
-insufficient fuel reaching the injectors
-vaccum leak at the intake manifold gasket or throttle body gasket
sounds more like a fuel thing if it cranks up the 3rd try. could be a bad main relay. do you hear the fuel pump prime when you first put the key to "on"
do you hear a clicking sound from the starter?
