B2D Conversion for the RT4WD (scrapped - pics included)
Hey guys, I had a couple scrap parts around so I decided to see how much work it would be to mount a d series tranny on a b series block. I have a b16a1 block with just a crank on it - the block is shot, so this is the perfect use for it - he he. And on the transmission, I did a tranny swap in a crx a few months back, the guy blew up the diff in it and other parts are shot too, so I pulled it apart so I could use the inner casing to test fit on the b16. I spent a couple hours on it today and was able to conclude that this won't be a direct bolt on, I'm going to have to do some cutting on the b16 block so the axle hub will go into the tranny on the drivers side. The top rear bolt lines up perfect so that's a good start and I was able to put a starter on the tranny and it clears good too, just needed to be spaced out about a 1/4 inch. Here are some pics of the first day.
Below is the top front bolt hole, it almost lines up - might be able to hone out the hole on the tranny to use this one - we'll see.
Below you can see there isn't much room for the axle, this part of the motor is going to be cut out for clearance.
Below - I'm use a d-series clutch and flywheel. 2 of the flywheel holes lined up so I'm just using those for testing. Since the b series uses an 8 bolt I'll have to figure something for that out later.
If you can see the line on the block that's how far the block is going to have to be cut for the axle to fit.
This won't work, that's what I was originally going to design, but since the drivers side axle won't go in the tranny because of the motor being in the way - see pics above - it's going to need more custom work on the motor and tranny to make this work. Everything mechanical (flywheel, clutch and starter) all seem to line up and work great, just gotta get the other couple things figured out.
You mean EE. Passenger side EF is opposite to passenger side EE.
EE = Left Hand Drive (Predominantly)
Saying 'drivers side mount' or 'passenger side mount' is completely pointless.
FYI when talking about sides of car just use left and right. It should always be assumed you are standing at the back of the car looking forwards.
wagon.....................4ever...............................
It should plug into the tranny - 4wd int shaft and 4wd tranny.
However, the bolt holes for the intermediate shaft in the B series block won't necessarily place the intermediate shaft in the correct location to "slide" into the RT4WD transmission. Here's hoping it does (for you sake).
The video I am making is exactly the harness you will need. We got sponsored to use Rywires conversion harness. If you have MPFI already then this conversion will be a BREEZE. If you have DPFI you'll need some extra work. I'm hoping to have that video up soon.
Or you can be a man and doing it yourself like me and this one dude did years back 8)
http://www.honda-tech.com/showthread.php?t=1319235
(btw I have heard nothing but good things of rywire)
