Thanks for sucessful rear springs and tow hitch
I just wanted to post that I have succesfully utilized Acura front springs to replace the tired springs on the back of my 89 Wagon. It raised the rear about 1/2 inch above centerline, and it really made a positive improvement for handling.
I have also successfully adapted a hitch to the back. I used it yesterday to tow our tent trailer and it did a pretty satisfactory job. Adapting it was a real bear and it would not have been possible without an arc welder to fabricate adapter parts. i utilized tow hook mounts as well as a through the frame bolt at the rear of the bracket. The tow hitch isn't going anywhere, but adapting it to the curve of the frame was a real bugger.
Thanks
  • hi! how's the ride? is it a liitle bit stiff for the rears?
    could you post some pics of the tow hitch you adapted.
    thanks
    wagon........................4ever..................
    let's have some pics and the model integra springs you used.
  • you wrote a letter...
    i want a postcard...
    where's the picture?
    :mrgreen:
  • gp70hsgp70hs Band Wagon
    The ride is less mushy than it used to be. It is a little stiff, but not bad. I'll work on getting some pictures. I pulled the springs from an 89 Acura, during a parts run at the pick the part.
    As far as the change goes, overall I would highly recommend the spring change. The car drives and handles far better, in my opinion. As far as towing, I need to fabricate some mirror extenders, before I feel comfortable I can drive it without getting pulled over by the Polizi.
    hi gp. i thought that 1st gen tegs have torsion bars for the fronts. pls correct me if im wrong.
    hey gp can you confirm this??
  • wantawagonwantawagon Band Wagon
    did you have to cut these springs? Specific year or a part number I can look for?
