Engine metal scraping/vibrating sound
Hey folks, new to the forum here, just picked up a 91 2wd. It sat for a while at the PO's and the timing belt broke on him one day...he had found a spare d15b2 so i went over there and swapped heads to drive it back home.
Put on a few hundred kms and then noticed a metallic clatter, scraping sound coming from the motor. My dudt shields are not attached and this happens whatever gear im, standing or not...its completely RPM dependent.
https://www.veed.io/view/3e784519-57a4-4eb2-834d-2449715dd714?panel=share
Sometimes it gets quite loud but generally very similar to what i recorded. I believe its the original motor ans trans with 284,000kms, 5spd.
