Engine miss and low idle sputter
My engine started missing recently while acellerating, around a week later the idle went much lower. less than 500. It almost died a couple of times I had to press the gas to keep it going. HELP! Could it be a fuel pump or filter? Electric. I just don't know where to start. Car has 217000 on it so I do work myself.
- pull the passenger side foot carpet up to see the ECU (big goldish box covered by a plate)
- start the car and see if the red light on the ECU starts blinking.
*if it does start blinking, check the codes online, do a search about honda ecu codes
my guess is your throttle position sensor (TPS) is broken.
- try a working distributor, 75% of honda's don't run right because of the dizzy.
MOST of the time a fuel pump either works or doesn't work.
hope that helps.
