Input Shaft Play
I was messing around with another HF tranny over the weekend. It came out of a running and driving car (slammed pretty good in the front). The tranny has way too much input shaft play. Is that just a matter of cracking it open and putting in new bearings or should I just avoid the thing all together?
Or is it attached to the input shaft itself? Does a guy have to need any special tools to do this?
It's more or less at the very bottom of the tranny case (clutch housing 1/2), and you need to remove everything else to get to it. It's an interference fit into the case, but some carefully applied propane torch heat will expand the case sufficiently for it to just drop out. Then you pry out the seal with a screwdriver and then perform the reverse. Heat the case again and the bearing slides right in.
He wanted $100 for it so I pulled it out intending to buy it. I discovered the shaft play after getting the damn thing out (front end met with a pole). I'll offer him significantly less and if he takes it I'll give this a try.
imput shaft itself, and not pressed. sometimes tight but with a heat gun it falls right out. sometimes it stays on the shaft, sometimes it stays in the case.
hope this helps.
