*SOLVED* oil drain plug won't come out, shop screwed it up.
i was on a long road trip awhile back and stopped to get an oil change at some quick place. now i went to do it again and the bolt just turns, not leaking. when turning the bolt it feels like it's going to loosen out then suddenly starts to feel like your tightening it.
probably gotta replace the pan, do i have to drop the header to remove the pan? i'll have to drill a hole in the bottom of the pan to drain all the oil out too. this is going to be a messy PITA for sure.
i thought i was done with the board, not yet i guess.
btween the pan and the bolt while loosen...
9 out of 10 it will give ...
Interesting idea. My wagon came with one of those funny drain plugs that simply screws in and out by hand. No bolt, just that's larger than normal. When I removed it and tried putting a regular bolt on during my first oil change on the car I realized that the threads were all screwed up, which probably led to this repair.
It seals OK, so I've just stuck with it. If I ever have a problem, it's good to know about this option. What was done for my car may be an option for quarters, particularly since he's not keeping the car...
i COULD sell the car as is and not mention this issue but that kind of behavior is reserved for people selling used BMW's.
it's sunny outside, i'll give something a try once my son wakes up from his nap.
glad its solved
I'd definitely recommend retapping it for the next larger size plug rather than the method employed on my car.
