Draw tite hitch?
I know absolutely ZERO about hitches, And how they work/mount.
Can anyone tell me if the trailer hitch from a Regular civic would bolt into our wagons? Here is a picture of the one I found for pretty cheap. Will this work? Apparently it’s a “Draw-tite trailer hitch off 1990 Honda civic” but I cant find the application on the “draw tite” website.
it'd be a good starting point just for the brackets.
+1
I wish I could get my hands on something like that and upgrade from my tow bar. I am guessing thats a 1 1/4" receiver which is fine, still more capable then my setup. I would guess that the wagon would need to drop a bit more; but I do know that the brackets are almost a guarantee to fit since the rail bolt pattern for the tow points/sway bar drop brackets are the same. Same reason we can bolt up a EF bracket in place of my tow point.
If its cheap I'd definitely buy that; would be simple to modify with a couple hours weld time.
Basically in the future Id like to use my wagon to tOW a dolly. On that dolly would be my hatchback.
I was hoping this would allow me to do that.
Guy only wants 25 bucks for it, we will see.
buy it. It's as close as you'll come to a real hitch for your wag. I will buy it from you if you don't dig it.
how much can I sell it for???
How much are these wagos rated to tow anyways?
