B-series intake ID question
My engine ('92 OBD1 B18A1) has this big fat ugly intake manifold
It's from an automatic car, so it even has (or had) EGR. I've looked around and been told to get a later model LS mani ('94-'96 i think?) like on B18Ctom's car. I traded for this one today:
I know it will bolt up, what I'm wondering is whether I need anything else parts-wise. I got it with the support brace and all(it's different), so that's ok.
It has the MAP sensor on the TB, I can just plug in the same wire from the present remote one? NO FITV...? no biggie?
So is this the intake I want? I'm not sure exactly what engine it came from, the guy i got it from didn't either.
wait, did i just say that...!?
Any specific shots you want of the intake manifold?
B18xxxx: that works, just wanted to compare visually- I just noticed mine's not drilled for IAT sensor?
Yeah yours is an OBD2 IM due to the lack of IAT and the throttle body lacking the fast idle thermo valve.
The IAT is located in the actual intake tube itself on the OBD2 Integra, and for some reason they also lack the FITV as well - my B18C5 doesn't have one, but it's never presented any problems. I run an OBD1 reprogrammed P28 with it and the fast idle circuit works as usual, etc.
If the lack of an FITV bothers you then simply run whatever TB you want to that has one on it. Again my C5 has never had one and it's ran fine for 8 years now.
Alternately, do you know where I can get an OBD1 ('94-'95?) intake?
...or you could source an OBD2 Integra RS/LS/GS/SE intake tube.
I'll probably just wait
