Which D-series can I swap in and keep 4WD?
I swear I've searched, but all I really saw was a couple "for sures" and a lot of contradicting... Maybe this thread can be added to the FAQ once people chime in?
I've got a '91 RT4WD with the 220,XXX A6 on it's last legs (~100 miles to the quart) and with it being my DD I need to find a running D16 to swap into it.
RT4WD compatible D16's are:
- D16A6 = YES[/*:m:sl9cxtu0]
- D16A1 = NO[/*:m:sl9cxtu0]
- D16Z6 = YES (IF IT HAS THE MOUNTING FOR THE INTERMEDIATE SHAFT)[/*:m:sl9cxtu0]
- SOHC ZC = YES[/*:m:sl9cxtu0]
- DOHC ZC = YES[/*:m:sl9cxtu0]
- D16A8/9 = YES[/*:m:sl9cxtu0]
- D16Y8 = NO[/*:m:sl9cxtu0]
- D15's = NO[/*:m:sl9cxtu0]
D16A6=YES
D16A1= NO
D16Z6=YES IF IT HAS THE MOUNTING FOR THE INTERMEDIATE SHAFT
SOHC ZC=YES
ZC/D16A8/9=YES
D16Y8=NOT SURE
D15's=NO
Actually any D-series motor (besides the 86-89 Integra because of the drivers side motor mount) will work. Some motors would require DPFI to MPFI conversion. Some motors would require OBD0-OBD1/2 conversion. Some motors will not have the mounting holes drilled and/or tapped for the intermediate shaft that the RT4wd's use, in that case you will have to run unequal length half-shafts. Unequal length half shafts have no negative effects on a DD, but cause torque steer to the right side of the car because of the torsion on the different length half shafts. ITs the same principle when using an extension on a torque wrench, the reading will be incorrect because the extension will twist causing a lower ft/lb reading.
Personally if you just want a good drop in motor that will provide a little more power and will probably cost the same or less than a D16A6, I would go with the OBD Non-VTEC SOHC ZC.
A D16z6 white out tapped holes can me dropped in whan you tapped te holes???
And err... second sentance i can't make head or tail of.
this might help
I don't know what a dohc ZC is :oops:
D16A8/9
ZC swap coming soon 8) (cheap and nice HP level)
till you wont to upgrade parts then your phucked! go with a z6 imo
they ask 900 Euro for a good one :?
Dohc zc 300 - 400 euro.
Already checked out http://www.d-series.org/
there are nice upgrades possible
Anything with the mid shat tapped is the rule over here.
you have to swap over the drivers side motor mount from the a6 motor.
Will this work in my 91 RT4wd civic wagon?
Can I mount this motor to the wagons 6 speed tranny?
None... this thread is specifically about engines that bolt to the standard transmission. No B's will bolt up that i know of.
I fit a D15 in my 4WD civic, I just finished it this weekend, the intermediate shaft has one bolt holding it in.
:shock: :shock: I don't know if thats such a great idea, only one bolt... Good luck with that
most 2WD models were dual carb, so you need the fuel tank and lines from an MFI wagon, loom etc..
no different to civic HB swop.
