PS to Manual Steering?
all i need to know is if i can unbolt the power steering system from my wagon and bolt up a manual rack without having to cut or weld or modify anything in anyway. i looked in the manual and it does not specify enough to where i can tell if i can do this. please i am begging anyone to help. and thanks in advance.
I know theres lots of guys with the DA's that are converting to the manual rack in thier cars (and they are using the civic manual racks as there are no PS-less DA's), but I havent heard what all is involved. Ill go over to g2ic and see if I can find any info.
-nasty nate
soo i dunno
but my point was B series swaps just require the pump and maybe the fittings at the pump ..
Thanks for the input though.
Nasty Nate
And can i just use a manual rack off of a crx or does it have to be a wagon?
Akira, Thanks! That site has a lot of really good tech writeups on it. Ive been a member of that site since around 98. Lots of good guys over there too. I even did a writeup on AT to manual for the teggys, along with a few others, like how to shave the keyholes using the rear door handles from a sedan and rear lower tiebar install.
