oil pan
how does the oil pan come off?
i already have all the bolts off and nuts. it still wont drop. what am i not doing?
spare gasket
enough free play
tap it lightly with a mallet to break the seal ?
Hopefully you didn't mar anything up to bad doing so; that is generally not the recommended way to do that. Try to take note of where it was you were prying and consider using some RTV/hondabond type on those spots so you can cover any leaks that may develop because of the screwdriver method.
and by any chance do you kno the lbs. its supposed to be torqued down at?
That is more often the case then not (the oil pan gasket that is); that or the front crank seal. Those two possible leaks couple with the fact that most people spill oil all over when changing their oil filters sure makes the pan seem like the culprit sometimes.
I cannot recall torque specs either (though it is not much, DONT overtighten them) but as someone else said, the sequence IS important.
