I put some lowering spings on my wagon and it is squating in the back i was wondering if any knows if i can put a lower crx control arm on to pull it back to normal stance.
wagons have a different rear shock just get the rear shock from any other ef and you will be fine they use longer springs in the rear so when you put a spring for and other model on the stock shock body the car becomes way too low ... soooo cut your stock spring or fing a different shock body
I used the stock body that came with the car and put the spring on there.The body the spring came with didnt lower it at all and that was the aftermarket one.
ok i dont follow you ... so it is too low with just the spring but the spring came with its own spring perch .... take a pic or somethin ...
but my point was a wagon is made with longer springs and to compensate the sprind perch is lower on the shock body but the over all end to end length is not much different than any ef shock and spring assembely there is a thread on this somewhere
