trouble recognizing park
Ok I have a 1990 rt4wd automatic, when I put my wagon into park it really does shift into park but on the cluster the light does not light up around the P unless I hold the shifter as far forward as it moves.(there is about an eighth of play forward from park) Now it also will not let me pull the key out until the park light has light up and also I noticed when the park light does turn on the idle drops and the car gets shakey, not when I put it into park just when the park light engages. Any help appreciated.
As for the shaky bit, that's probably a low idle that the car goes into once it fully realizes it's no longer in gear (it has to maintain a higher idle to not stall out.
except for asking ...
it helps ...
