obdo code-19?????
hey guys well i bought a new 2wd 5 speed wagon last week, it was running fine then it just wouldnt start. it was trowing code 16 and 19 but fixed the 16 but not the 19 wtf iz it anyway.?.?. car still running but takes awhile to start and runs kinda ruff!! cant seem to find out what iz causing this, any help would be appreciated!!!! :(
    http://fourthgenhatch.net/helms-ecucodes.html
    lock-up control solenoid valve... auto tranny
  • 91awd91awd Wagonist
    ok but my car is a 5 speed, that could possible mean that i have an auto ecu?? what code is it for an auto, mine should b a pm-5 right!!?? :? :?
    Possible. I swapped ECUs between my auto 89 RT4WD wagon and my gf's 5sp 88 CRX Si for troubleshooting purposes, and her ECU ran my engine just fine. (Don't know if my auto ECU runs her car, since it's her car that won't start, but I can tell you the ECU isn't the cause of that particular problem. :) )
    if you haven't figured it out yet, I found my Code 19 to be a bad ground.
