wheel offset
tried searching but no results came up. and the sticky up top just has what OEM wheels off other cars could fit. so maybe we could get this stickied up top also.
i was thinkin and lookin and there are a ton of different wheel setups with size and offset. also there are problems like rim hub size hitting the caliper and tire size rubbing the fenders.
so if i wanted to run a 16x7 rim what offset would i run? i dont want them to stick out past the car and i dont want to tuck since im not goin that low. i was thinkin like 40mm-35mm would be safe. i know i ran a 16x7 on my crx with a 40mm offset and it looked good.
also maybe in your reply you could tell what size rim/tire combo and offset for reference so another post isnt started like this again. or am i starting something already done???
Not saying you SHOULDN'T do this - there are good reasons to, for performance as well as looks. Just saying it's something to be aware of.
Its lowered but not a lot (not tucking) the front sits *just* outside the guards but the tops of the tyre are about flush. The rear sits well under the guards due to the camber (not camber correction) I have even added 5mm spacers to sit them a bit further out so they match the front a bit better.
The wheels are a stock size/offset for a VW golf so I would imagine that there wont be any damage caused to bearings or anything from this
how come only 4 ppl have posted???
i just test fitted my set and it looks sickkkkkkkkk but its gunna take some work
What about back spaceing?
IM lookin at the Borbet LV4
eather i can get it with a 5.08" backspaceing or a 5.51" back spacing
what would work better for the wagon?
Also what width?
I would say you could go as low as 15x7" +25 all round without causing an issues with rubbing, especially when lowered so that they camber in
