Z6 into 91 RT4wd
alright i have a 91 rt4wd first one an im inlove
..sad story short i drained coolant and went outa town for work came home to find out a buddy drove it for about 2 hours with no coolant
bye bye a6 she ran strong with teh 211k to..annyways im pickin up a z6 longblock today an gonna swap it in tomorrow just wonderin what exactly do i need to do the swap i read a few threads but ppl got go back an forth on how to do it. im just wondering if anyone has a step by step thread with pics an all that..all info with with tahnks guys..
but thanks for the link to rywire! very helpful an thanks for the fast response
http://www.hondacivicwagon.com/bb/viewtopic.php?f=2&t=4980&start=0
Are you sure Shenrie? I was under the impression 1.6 blocks had the holes drilled and tapped. northwest_war_wagon has a complete Z6 in his rt4wd and from what I remember he is running the intyermediate shaft. I might have to double check this...
I just sold a D15B motor cause I didnt wanna hassel with it. Hoipefully his has it since its prolly installed by now though. If they do have them, please post up the info. Specifically where the block came from if known.
Not all SOHC ZC's were VTEC and I would bet that most D16 blocks had the holes drilled and tapped. I'm going to go out on a limb here and say that the only thing different between D16 blocks are machining procedures and minor modifications. Thats why parts are very intechangable. I could be wrong and I'm willing to learn.
Bingo!
I know there's differences with the Z6 and Y8 blocks as well...
...but really, you've come this far... why let a little tap job stop you?
And yes, MSD makes a rpm powered switch. They have removable chips for all rpms. Pretty handy actually, but you need a relay to use them properly.
true that there are zc's that arn't vtec, 115hp if i remember right, there are even carb model's also also if my memory serves me right, i know dohc's for shure.
Are there holes for the intermediate shaft and what clutch would you use?
