Wagon-only oil dipstick?
This sounds really dumb, but I need to know if the oil dipstick for the 88-91 wagons is the same as the civic/crx's of the same years.
I need to know because I have a stick out of an old DX hatch and if it is correct I have NO oil in my car, even after putting a litre in and driving ~25 km's it says I'm empty. I also did an oil change no longer than 2 weeks ago and out in 3.5 litres then as well.
I don't see any oil puddles on the ground where I park and the motor doesn't seem down on power so I have a hard time believing I am burning 3 litres in two weeks.
Any advice would be appreciated,
After a bit more investigation, according to the parts listings from Majestic Honda (www.Hondauatomotiveparts.com), the following cars all have the same dipstick and dipstick tube:
1990 Civic hatch Si (1.6)
1990 Civic hatch DX (1.5)
1990 Civic Wagovan RT4WD (1.6)
1990 Civic Wagovan DX (1.5)
It looks like I did have the correct dipstick, so my best guesses are that either;
A - Rear main seal leaks a LOT. This seems unlikely though because it should still leak under the car and there are no visible leaks.
B - My car is burning oil at higher RPM's, so I can't tell when the car is just idling.
I've just ordered a gasket set of eBay and I pulled a spare DPFI intake manifold off a car at the wreckers. So over the week I'm going to strip and clean the manifold and hopefully track down the oil leak when I replace it. I'm also going to replace the PCV valve and that black box at the back of the block. I'm not even sure what it does but I hear that cleaning it can help.
sounds like you are leakin massive amounts of oil. should be all over underneath on the car or your motor needs rings now.
