Need help with my 86 wagon not starting :(
Noticed the little battery light flickering this morning as I drove to get coffee. Drove fine, started fine. Once I came back after turning it off it cranked and immediately came on, then quickly died.
Now, it turns over but won't actually kick on and start. Checked a few things and it is getting fuel and spark. Tried starter fluid with no luck.
Could it be the timing belt? Obviously it's not the battery since it's turning over (and I checked the battery with a little voltage thing just to be extra sure) but why would that little light flicker?
Thanks!!
Thanks!!
Thank you for that awesome advice! I'm at work right now but I will try this as soon as I can.
If it is worst case scenario, and the timing belt is toast, where can I find a decent walk through for replacing that belt? I know I've asked around at mechanics just for general maintenance purposes and I've been quoted $500 just to replace it!
I understand it's a tedious and precise thing to replace but I have faith in my buddy when it comes to things like this. He however has not done a Civic timing belt replacement and is asking specifics that I don't know such as if there are pulley markings to line up with etc.
I ended up doing the distributor check and thankfully it was spinning so we narrowed the issue down a bit. We rechecked all the fuel and spark and everything appeared fine.
Eventually we sprayed the hell out of the intake with starting fluid while cranking it and giving it gas and after about 10 rough minutes it FINALLY hacked up a lung and started up.
It's still acting a bit pissy and the battery light flickers as it warms up in the morning but it WILL start hesitantly. This weekend I will be looking in to a new carb kit, fuel filter, and fuel lines.
Yea it almost seems like an electrical problem but I really have very little experience in that department.
By the way, does anyone know a great website I can buy the manual from? I only ever see the Haynes manual for CRX/Civic but it's not wagon specific. I just need a third gen workshop manual!!
Sounds like my uncle Joe !!!
