DOHC ZC swap ??'s a/c, PS, ecu (not covered in ZC swap info)
I have questions for a TURBO (a/c compatible) DOHC ZC swap:
(in a rt-4wd)
A/C (from TX a/c is a must)
-What would I need to be able to keep the a/c when doing a dohc zc swap?
-Would I have to find a DOHC ZC a/c compressor or would the OEM SOHC one work?
Power Steering Pump
-Could you just get a NON-PS rack and pinion from some DX civic?
ECU
-What obd-1 ECU should I use with the DOHC ZC? (for tuning)
(in a rt-4wd)
Power Steering Pump
ECU
Most tuners these days are going OBD1.
I use to rip out the a/c until I moved to southeast Texas where the humidity alone kills.
From what I understand, your stock SOHC A/C unit should fit the bracket on the OBD0 ZC, not sure about the OBD1 bracket. I guess if it doesn't fit you'll have to make it work between the ZC bracket and SOHC bracket.
As far as an OBD1 ECU your best bet would be to get the one made for the ZC engine. If you're going all out and tuning it with crome or uberdata you could probably start with the single cam non-vtec and chip it. I think that's like a PO5 or something.
**-edit- the non-vtec OBD1 is the PO6
The PS pump and bracket are PM7/ZC specific.
