'884WD clutch bracket busted
So I guess it's my turn for the clutch bracket to go. My dad and I pulled off the damaged one yesterday.
I ordered a new one from the dealer. Problem is, there was none available specifically for an '88 Wagon 4WD. The only one available was for a '91 Wagon DX, part # 46590-SH5-A41. My dad calls me at work and tells me that it won't work. Not that I don't believe him, but I gotta see it for myself.
So my question is. Has anyone replaced theirs before? If so, what part number and application bracket did you use?
If this doesn't work, I may have to resort to welding my broken one. Otherwise I will have to spend some quality time at the junkers trying to find the correct one.
TIA
TIA
I read somwhere (probably here) that the sedan and hatch EF clutch bracket are slightly different size to the shuttle ones
