Composite hoods for Wagons
I'm going ahead and getting a mould made for a hood for my car. My only concern is how to make the bottom side of the mould. I have no need for the hood latch for my application. I will be going ahead with the hinge mounts though. If there are enough of you interested in the OEM configuration for the hood, I will go that route.
Is anyone 100% committed to a CF hood made by a professional firm for $500 plus shipping? Chances are shipping will be in the $100-$175 range depending on your location. Shipping will be from Blaine, Wa 98230. I can meet up with some of you in the Vancouver BC to Seattle corridor, but that's a far as I can go.
This is still in the very early stages, and none of these numbers are finalised.
Let me know what you guys think. This is not a "if I get 10 people, I'll go ahead and have the mould made" situation. I am having the mould made no matter what. The only issue here is what configuration the mould takes, based on the need to satisfy other interested parties.
in what issue?
id like to see this
http://www.importprecision.com/fiber_gl ... da_crx.htm
oh, they also have the zc hood:
http://www.importprecision.com/fiber_gl ... crx_zc.htm
nope wont work... hood = wago specific
Heres an old pic, work in progress really
heres the last 1, it want that bad but jus gotta be patient
Then I came across a guy that is in college for composites, and apprenticing in the Boeing composite labs down in Seattle. He was quite keen on working with me to build a hood. It seems that there will be some pretty advanced technology going into this hood. It's vacuum infused with a foam core, and we're shooting for between 8 and 10 lbs. Once the 1st hood is done and tested, he's planning on making more. I have no idea what he'll be charging.
Here's a pic of the mould for the skin:
I thought I wanted dry carbon (the way it looks in the pics), but the maker convinced me to put clearcoat on it to protect the carbon and resin from UV. Once it's all together, a nice coat of high end UV clearcoat is going on it.
I can't wait!
BAD A$$ ! ! !
Almost done!
How would the hardware attach to it?
Then it just bolts in like normal.
I'm going to link him to this thread so he can come in and give you guys the numbers.
Jacques
