help... quick ... is it my battery?
Ok, car didn't want to start a few minutes after it had run yesterday afternoon. Starter chugged down like the battery was almost dead. Waited about 15 min and it started, barely. Brought it home and it started like nothing had ever happened, a few times in a row.
Went ahead and cleaned the battery posts, cable ends, ground strap where it connects to the block. This morning it didn't want to start again. Tried running and then after it chugged a few times a relay gave me a few clicks.
I've got the battery being charged at a local place my friend works at. He said he's got to charge it and then he'll be able to test it and tell me if the batteries ok.
I'm kinda thinking that the batteries old and just needs to be replaced. What else should I check?
Just didn't want to spend the cash on a new battery just to find out that it was some weird relay or bad connection.
Proper battery filling.I can't believe several auto shops say not to fill them('cuz they want to sell you batteries).
Pop the top.look into the 3 tubes.It looks like a cup with the bottom cut out & slots cut into the sides.
Fill it w/distilled water to the bottom of the ''cup''.You'll see the water pucker as it touches the bottom of the cup .Now do the other 3 if needed.
:shock:
